MR11
Lowering Is 350 New Shape
35 posts in this topic
Like to hear from anyone who's lowered one of the new shape IS 350's in Perth ?
Who'd you use & how much did it cost ?
Share this post
Link to post
looking into this atm.
for me its between the tein h spec / RSR* Down as both are mild drops.
but considering to just wait for eibach to release the pro-kit.
Share this post
Link to post
Eibach do make springs for these. They say drops the front 25mm @ the front 20mm at the rear, which sounds about perfect.
They're "30% stiffer" than standard they say which im not sure if it going to be too rigid. Apparently any spring that lowers the car has to be stiffer to compromise for the fact there's less travel. Im just hoping they don't make the ride too rigid, as i think the current spring rate is spot on !
$900 fitted, wheel aligned to do the whole car if that helps ?
Share this post
Link to post
Eibach confirmed they are still under development (see below)
Im going to go with RSR down - ordered via frsport.com - $450 aud shipped.
drop numbers
front 30-35mm rear 25-30mm - perfect!
Share this post
Link to post
Yeah Eibach do make springs for these, ive just had a suspension shop confirm they're availability.In fact thinking of getting them installed next week.
Do you know what model RSR's were used in the white F sport in the pics, as that height looks about perfect. Not sure if thats your car or what the ride is like ?
1- 1.3 is a big "range" for a drop.1.3 would be too much i would think, especially at the back, as its not as high as the front !
Share this post
Link to post
You can use the 2is on the 3is (Eibach)
Check the part number it will be the same
Email from Eibach
The Eibach Pro Kit to suit the latest generation Lexus IS series is still under development, I anticipate that it would be available toward the later half of the year.
Best Regards | Mit freundlichen Grüßen
John Kayik | Sales Eibach
Eibach Suspension Technology Pty Limited | 3/4 Prosperity Parade | Warriewood NSW 2107 | Australia
It's 1.3 front and 1 rear (rsr down)
Sounds good to me.
Share this post
Link to post
You can use the 2is on the 3is (Eibach) ??, meaning ?
Share this post
Link to post
Look above
I'm saying you can probably use the same springs from the 2is on the 3is
Anyway just passing on info
Good luck with it and post pics if you get them in!
Share this post
Link to post
Hey Vaku,
I tried looking for these springs at frsport.com but couldnt find them.
Have you got a link to them?
Also, what did you pay to have them installed?
Share this post
Link to post
Wow! 265 for install and alignment!? Or install only?
I tried lexus perth, and they wouldnt do it (but if they were to do it, they said it could cost around $700).
Peddars quoted 600-650.
And a local suspension shop said around 500.
Am I getting ripped? Or is it just WA prices?
(lol I know for sure ppl from sydney are always complaining about the price of coffee here in perth)
Or is it maybe shops in perth dont work on lexus often so they are quoting more in case it takes them more time?
Share this post
Link to post
install + align.
getting ripped.. just find a good independent suspension shop, it really should cost you no more than $300!
im booked in for my install next tue :)
Share this post
Link to post
updated pics, install ended up costing $350 as they have not worked on one yet and didn't want to rush the job.
Share this post
Link to post
Looks fantastic vaku. Got any closeups of the wheel arches?
Do you know what the final camber is? And if there any camber adjustments done when doing the alignment?
Share this post
Link to post
Thanks, I will take some this afternoon and post them up - still some wheel gap but imo sits great ride quality is essentially the same as stock just ever ever so slightly firmer ( and I am very picky re ride/comfort) and the whole car sits about 11-12cm off the ground, the only thing that is lower than 10cm is the plastic wind diffuser wings thing under the front bumper that will scrape if you do not take an angle but even so it hardly touches it - so really, could not be happier with the springs!
progressive springs really do make a difference, I wasnt interested in coilovers (illegal) and I didnt want to wait out for the pro-kits (had them on 3x cars) so took a gamble on RSR's, and would highly reccomend them to anyone interested in a mild drop, no sacrafice to ride comfort and still legal etc for a reasonable price.
unfortunately I forgot to ask for the spec sheet, was too distracted looking at the car + had to hang around the workshop for 4hrs so just wanted to go home lol.
but yeah Michael @ garage 88 said I have more tyre contact now than when it was stock and it apparently has the same if not less camber, so worked out very well.
Share this post
Link to post
Anyone running roll centre adjusters in a is250/is350?
Share this post
Link to post
Looks great Vaku, & $279 for the springs & $350 to fit ? bargain i say.
You had 4 pple in the back yet, you get any rubbing/scrapping ?
They're the "progressive" springs, meaning the get stiffer as they get down into the lower part of the stroke ?
Great that you say not a lot stiffer than standard too ? Just took my F sport for a drive in the country & was really thinking the same as wouldn't want the ride to be much stiffer at all, otherwise starts to border on uncomfortable !
Take it you just the to go over speed humps at an angle now ?
Share this post
Link to post
No only 2 people but id say it would be fine as it's still above 100mm lowered - I did remove the 2x plastic pieces that sit infront if the front tyres as they did scrape a little on some higher speed bumps etc - makes no difference to the car at all in my experience.
Yes just angle and it's fine, in fact I have had no problems with ANY driveway / speed bump (since plastic removal which can easily be reversed) with the exception of a townhouse I bought - but the driveway - road angle scrapes standard cars.. It's pretty bad.
Slightly firmer but no complaints overall and no rattles etc, I have no intention of going back to stock springs unless I'm selling it!
Share this post
Link to post
Sorry meant to say have you had 4 people in the car yet, (including 2 in the back?) & if so does is scrape then ?
What do you mean re the removing of the 2 plastic pieces in front of the front tyres ?
The springs where $279 ?
Share this post
Link to post
No the springs are $450 from frsport.com
No have not had 4 people only 2.
Have a look under your car infront of the front tyres, see that plastic thing hanging down - that.. It just touches some driveways and speed bumps not a major thing but I just removed, makes no difference to driving I asked Danny what they do he mentioned makes the tyres easier to turn at high speed.
Share this post
Link to post
Hey Vaku, just looking at getting these myself. You still happy with yours & the ride comfort ?
Whats it like with people in the back too, does it rub ?
That link, was for 2 springs, presuming theres no front or back to these ? you got 4 of them ? works out to about $763 for 4 INC freight to WA !
Share this post
Link to post
I think Vaku sold his 3IS :(
Share this post
Link to post
check out my forsale section
i have set of teins for the 3rd gen is
Share this post
Link to post
