Dashcams
BobU
I should have mentioned that I need two supplies one when the ignition is OFF & the other when it is ON as I have the Blackvue Power Magic Pro which switch's the voltage when & as required.
Thanks for your suggestion though.
  • 3 months later...
It is possible & quite easy to get both accessory & direct supply from the around the 12v battery compartment in the rear.
