Satnav Time Set
Latest Member Posts
Aristo - Audio Issues
Hi, I have a few issues with my sound system in my Aristo - fitted with the JBL set up. Firstly my rear left door speaker was crackling and popping so I replaced it with an aftermarket solution - however that didn't fix the problem. The front centre speaker also crackles lightly under certain audio conditions but I'm unsure if its the same issue. Separately I also have an issue with the subwoofer cutting in/out on its own accord. I'm now guessing these two issues are related, is it more likely a wiring issue/grounding issue or the amp unit itself? How on earth do I go about debugging this? Is there a wiring diagram that shows which wires go in/out of the amp? At least then I could try and piggyback off the signal to eliminate the wiring between the stereo-amp and/or amp-speaker. Any thoughts or past experiences with this? -
5
NX450H+ 12V Battery Flat
I Trickle charge the 12v battery using an extension long cable pass through left hand side rear passenger window, ( lower the window just have enough gap for the extension long cable to pass through ) that way you don't have to keep the tailgate opened or crash the cable under the tailgate while you are away on your vacation
