When I make a turn of 90 degrees or more, my rear left door sensor activates momentarily, with a warning on the dash and interior light comes on.
Door is definitely not ajar.
Has anyone had this problem, and aware of a fix?
Vehicle is just over 4 years old (IS250x).
Thanks.
Have a look at the rear left door door sensor. It's held in with one screw from memory. Take it off and see if the internals are damaged or not.
I had a sorta similar issue with you with the same door - except when opening the door it light wouldn't come on cos the rubber boot fuse the switched close.
Probably because I don't use that door that often.
