Wheel Swap
Hi, Just wondering if 17 inch is250 wheels are interchangeable with standard 17 inch is300 wheels. Is the offset similar/ same. Current is300 tyres are 215 profile. Others are 225 and 245. Not sure if there would be any issues with tyre rubbing, too. Hope you can help.
IS250 wheels will fit fine, the offset is 5mm different so the wheels will sit more flush with the body. I am running 18" IS250's with a slight rub on full lock in the wheel well (the plastic liner).
