wana turn that useless dash tray into something more useful?
this is wot i learnt from a jap altezza site a while ago, and thought i'd share it with you guys :-- )
1) Take out the dash tray by using a screw driver, i put tape on the tip so i don't scratch the plastic.
2) Underneath the dash tray, you should see two screws, undo them and that useless surface will come off.
3) Trim a non-slip rubber mat to the size of that surface, but leave about 1 inch on all 4 edges, so you can fold them and by using tape or whatever, tape them down. And make sure they are taped on tight, otherwise when you turn it around the surface will look gay.
4) There you have it..! Put you sunnies on that and they won't slide off..! 8--- )
