Hi guys
I have not been able to find my particular problem posted anywhere. I have a 1993 LS400 with air suspension and the problem is that, when parked, the rear of the car is always lower on the left side by about 2cm.
I have two NEW Toyota rear air shocks installed. I rebooted the suspension ECU (many times) and even switched around the air lines to the shocks from the air control valve in the trunk. The sensor links are both at the same length.
The front height is perfectly even on both sides.
Any ideas as to what could be causing this annoying list?
