FYI
After hid installation, my dashboard has a error message of "check VSC", engine and traction lights up amber. I was like WTF.
spent half hour surfing the net try to find the solution. no answer!
Spent another half hour with car try to figure out wtf was going on, it turns out i did not tight up the C-ring (the one holds the airbox and the piple) computer detects an air leak which generates an error.
tight it up , reset the ECU , problem solved.
i had the same problem after installing my HIDs as well. i spent about 15 minutes with the car, couldn't work it out and just left the car peeved off.
came back a couple hours later, started her up and it was gone. i didn't do anything and haven't seen that error since.
