i got an altezza RS200 & took out that panel under the stereo out & found 2 wires(one on either side) taped up. it looks like its meant to plug in to somewhere perhaps a switch or something. an altezza AS200 owner in UK also told me the same when he took that panel out & does not know what its for. so those wires most probably be there if any of you NZ altezza owners have a look at it on your altezza's.
anyone know what is for? is it for seat heater?
i believe seat heaters & traction control switch are located on same panel under the radio for the euro/ australasia spec IS200/300.
thanks...
sounds like trc is off permanently... check the forums here or the uk that will help you identify it is the trc that has been switched off permanently.
