Hi,
I took my car for service to a toyota service . They over filled engine oil around about 200ml more than recommended. (6.3 l +200ml) i.e the oil level in dip stick shows it is above the high level. Will that be a problem ?
Because I provided them the with 7 liters engine oil ( Mobil 1 5W - 30) .
I was returned with a bottle of 500ml left.
The reason why I am concerned is because there is an engine noise (vibrating noise) for the first 10 - 15 mins after starting the engine. But once it gets to the operating temperature the sounds seems to disappear. This never happened before the oil change.
