Seeking help in regards VSC light came on in 2006 is250. Checked with mechanic, seems like its transmission solenoid. Does any one else has same problem. If so what are the solutions. Is parts easy to buy? Are they cheap?
does it need to reprogram after installation?
  • 1 month later...
had same problem, was told to replace whole transmission instead of just solenoids as if you replace just the solenoids after a while the check vsc error will come back again
