1jz is200
Hey all,
I'm in south aust and do the odd track day, hill climb road stage and the occasional street meet and hills run.
My ride is a 2000 is200 lux manual which has a 1jz fitted running 490hp.
Current list of parts:
Soarer non vvti 1jz
Early supra R154 gearbox
Custom Tailshaft
Camtech 272
Golebys valve springs and seats
ARP head studs
Cometic Multilayer head gasket
Walpro 360 e85 Fuel pump
Racetech surge tank with extra Walpro 360
Bosch 1000cc injectors
R35 GTR coil kit
Sard fuel pressure regulator
Billet fuel rail with extra brace
Adaptronic ECU
Adaptronic Boost controller
Adaptronic Flex Sensor
GCG Garret GT35R turbo
GCG Turbo Manifold
Tial 35mm ext. gate
3.5” dump
3.5” stainless steel custom exhaust
Osgiken Super Single
Racetech vented catchcan
MCA Red coilovers
TRD 2 way diff centre
TRD rear strut brace
TRD Front strut brace
Cusco upper control arms with Camber adjustment
Cusco Front sway
Cusco Rear sway
Cusco Front version 2 arms and chassis brace
Cusco Rear version 2 arms and chassis brace
Hardrace front caster tension arms
Hardrace solid rear diff mount
Toyota JZX100 Diff
Toyota JZX100 6 bolt axles
New lower assembly ball joints
Battery boot relocation
LS400 front brake caliper conversion
DBA t3 4000 Slotted rotors
Toyota new mechanical factory power steering pump with custom lines and breather
Setrab oil cooler
Velo race seat
Edited by digitalpeer
spelling
