Hi guys,
I have these H11 led: https://www.philips.com.au/c-p/11362UEX2/ultinon-essential-led-headlight-bulb
For some reason I can't turn the bulb to lock it in place, it seems like the 3 notches are too thick....
I can remove and install my OEM philips H11 with ease.
It's a simple process, line up the the wider notch into the wider notch opening and then turn clockwise. Even with pushing force it can't turn and lock in. Tried both sides.
Any advice?
Installed, all good. Close thread. Cheers.
