My Soarer Cuts Out At Speed
Hey mate,
Quite an odd one there!
Most likely an electronic problem somewhere along the lines.
First thing i would try is an ECU reset. http://soarercentral.com/sc-forum/messages...html?1098228107
Dont be fooled, the pics are of a v8 but the fuses in the 1jz are the same.
If that doesnt fix it then make sure that any piggyback things you may have plugged into your ECU (SAFC etc) arent being dodgy. Try disabling/disconnecting any.
If you still have problems pop on over to the Soarer Central forums where all the gurus live ;D
Soarer Central
