All this was going to go into my LS400 but it will be getting sold soon so all the car audio equipment is for sale.
Some items are brand new still packed in orginal boxes and some are second hand items I purchased but never used.
Can email high res and other pictures on request.
Email me at [email protected] if interested in anything
Brand New Items Still In Original Boxes
JVC KD-DV6105 – CD/DVD/WMA/MP3 Player
Price - $400
Front AUX Input ensures easy connections with external audio devices. Superior sound is made possible by a MOS-FET amp, 24-bit resolution DAC, and Digital 7-Band iEQ. Dual Zone is also available.
Front AUX Input
The KD-DV6105 comes equipped with an AUX input conveniently located on the front panel. This permits easy connection with external devices – including digital audio players – and easy enhancement of your in-car audio entertainment.
Highlights
• Power Output: 50W x 4 Max.
• MOS-FET Power Amp
• GIGA MP3
• Digital 7-Band iEQ
• DVD-R/-RW, +R/+RW, VCD Compatible
• MP3/WMA Compatible with ID3/WMA Tag
• CD/CD-R/CD-RW Compatible
• DTS/Dolby Digital/MPEG Audio (2ch)
• 24-bit DAC (Audio)
• Adjustable Line Input Terminals
• 5V Line Output Level
• Line Output Terminals ( x 2 pairs)
• Front AUX Input
• Video Output Terminals
• Second Audio Output
• Subwoofer Output Terminals with Level/Frequency Control
• Optical Digital Output
• Flip-down Face
• Rotary Encoder Multi-Control
• Dual Zone Function
• Multi-Function Wireless Remote Control
*In conjunction with KS-PD100
DVD Section
• Video Format: NTSC/PAL
• Chapter Access (for DVD)
• Pause/Step/Slow*
• VCD Playback Control
• Direct Track Access (for VCD)
• Last Position Memory
*Remote control only
CD Section
• CD Text
• Disc Name Registration
• Random/Repeat/Intro Play
• +/- 10 Skip Function
Changer Control Section
• MP3 Control*
• CD Text*
• Direct Disc Select (1-12)
• Random/Repeat Play
• Skip/Search
* In conjunction with CH-X1500.
Tuner Section
• HS-II Tuner
• 18 FM and 6 AM Presets
• SSM (for FM)
• Seek (Up/Down)
• AFNS/PNC
• Stereo/Mono Switch (for FM)
• Auto Antenna
Amplifier Section
• Source-Specific Volume Control
• Balance/Fader Control
• Volume Attenuator
• Loudness Control
• Max. Amp Gain Switcher
Display Section
• Blue-Color Display
• White LED Backlight
• Switchable Dimmer
• Level Meter
• Power Switch Standby Illumination
General Section
• Detachable Control Panel with Carrying Case
• Tel. Muting
• Power-Off Mode Eject
• COMPU PLAY
• Preferred Setting Mode
Splits Pods
Brand New
Made from fibre glass. with a grey cover and an MDF base which bolts to the car.
They are approximately 10 cm deep at their highest point and about 3 at their lowest.
Angled towards the middle of the car so the sound is directed at you.
Designed for 6.5" Mid and space for a tweeter to be mounted also.
Price - $50
Used
MTX 12” Sub & Box
MTX Thunder 400 Sub And Custom Made Box
Max Power 400w
Dual Voice Coil
Normal Power 250w
Price - $180
.jpg
  • 4 weeks later...
  • 1 month later...
