1998 Gs300 Engine Bay Noise
Latest Member Posts
Cause of valley plate coolant leaks
An American you tube posting claims the longer life pink coloured coolant is the cause of premature valley plate coolant gasket collapse & that this can be prevented with the shorter life red coloured coolant. Can anyone confirm the likelihood of this being true ? As the proud owner of a 2018 GS F with 40k kms I am keen to avoid this valley plate problem if possible & consider more frequent coolant replacements a small price to pay. -
Map Upgrade?
Hi Kenn, mine is a 2012, I did not pay the $200-300 upgrade for each map, just seemed like bad money, does mean my map is pretty funny at times. I just use Waze. It updated through the USB, I have not found a way to get around it but have not tried hard. Pretty sure if you empty your wallet at the Lexus service centre they can help you. Sorry I could not be of more help. -
2006 IS350 Brake rotors & pads recommendations
Good Morning everyone, I'm looking to replace the rotors and pads on my IS350. I've been researching for some time now but I just can't settle on a combo. The car is my daily and I plan to take it to trackdays on Carco raceway in WA. What rotors and pads would you recommend? So far I found mixed reviews. Some recommend the DBA T2 or the Dixcel SD or Bosch. Some are recommending the EBC yellowstuff or the Dixcel type S pads while others says just go full OEM all around with better brake fluid and lines (next on my to do list). I don't mind paying for quality but I don't want to overspend on brand names, looks or something I don't need. Don't care about brake dust or looks. I just need something that work and I don't want a setup that sounds like grinding metal everytime i stop at a traffic light. I'm planning on replacing the brake line next but for now I need to replace my brakes first as they are approaching the end of their lives. For the tyre's department I've got a set Michelin PS5 installed. All of your suggestions are very much appreciated. -
Lexus wood trim for Australian model
Hi I have just purchased a mint CT200h one owner which is a bit light on trim. I have researched some trim packages available, they are mainly from the USA and don’t ship to Aus possibly because of the left/right hand drive but kits of wood veneer and carbon fibre are quite affordable. If I could obtain them could I upgrade the current trim with this package? Has anyone had any experience doing this? I would appreciate any information or advice on this fine vehicle. Thanks Peter
