st87 Posted October 12, 2011 Share Posted October 12, 2011 Hi guys, this is my first post and I think I'm going to use it to ask everyone if they are familiar with the front position lights which appear to be on as well when your headlights are on. In the manual, they are only referred to as 'Wedge Base' globes, but that sounds very vague. I found some LED globes matching that description that also says "T10". Is this the same fitting as the on my IS250? Thanks!! Quote Link to comment Share on other sites More sharing options...
334mm Posted October 12, 2011 Share Posted October 12, 2011 If you are parking about the parker lights then yes T10 is what you are looking for. Try not to buy the $1 ones, cause they tend to blow up quickly, and they are annoying to install. Quote Link to comment Share on other sites More sharing options...
s.gregory Posted October 13, 2011 Share Posted October 13, 2011 Also known as a 168 - if that helps. As above, install is pretty fiddly but not too difficult. Just make sure the globes you get will fit through the hole where the parkers stick out. Quote Link to comment Share on other sites More sharing options...
st87 Posted October 13, 2011 Author Share Posted October 13, 2011 Thanks guys! They would be much easier to install than the headlights at least. I just fitted HIDs on mine and I had to remove the air filter to get to the driver's side! The parkers appear very straight forward... pretty much just have to remove the panel if memory serves. Quote Link to comment Share on other sites More sharing options...
