Hi guys,I have a 2006 is250 and my touchscreen has stopped working.all the buttons work but it doesn't register touch,I tried the digitilizer fix that I found on the forums but that didn't work so I need to order a new screen.just wondering if anyone knows the right screen size whether its 7" or 7.3"? I believe it is 7" but I do not want to order the wrong size!.thanks in advance guys
Lushpuppy,
I had the same problem last night. The touch screen is no longer working as well.
Did you end up replace the screen?
Thanks.
Hi Brandon,
yes I did replace it..I ordered one off eBay,it cost $150 and it works perfect..it isn't toshiba but I know you can buy those on eBay for around $400 I think.its not hard to replace yourself and so much cheaper then getting lexus to do it!!..just make sure you ask the seller if it will fit your year model!!
Good luck
Thanks Lushpuppy. I found a DIY on youtunbe for fixing the screen but it looks too complicated. I am scared I might ruin the whole unit. Here is the link on how to fix the screen:
Did you replace the screen yourself? Do you have an instruction how to do it?
Brandon
