Hi All. i recently picked up a 2000 GS300. I wanted a reliable, smooth ride so what better than a 2j with silky smooth vvt-i.Going for the VIP look (rims, coilovers, tint, exhaust) I thought better open her up first and change all fluids,timing belt, plugs, leads etc.
post-8513-0-70304700-1448738488_thumb.jp
fine so far but after further delving discovered the harmonic balancer was cracked. So a new one was fitted along with an original radiator and hoses as the original had a crack. Other work which was done all at once lists as follows;
  • New Optima yellow battery
  • New spark plugs and leads
  • Cleaned air mass meter and throttle body
  • New water pump, thermostat, cam and crank seals
  • New timing belt, tensioner and hydraulic tensioner.
  • Cleaned VVT-i controller filter.
  • New braided brake lines(bit better response over factory) and flushed brake system.
  • Installed 2nd hand TRD cat back exhaust.
  • Replaced both upstream O2 sensors.
  • Installed 2nd hand Cusco coilovers
  • New intank fuel filter
  • Installed genuine Pivot voltage stabilizer and earth kit.
  • Extra cold air ram and another hole cut into air box for added air.
  • Spare tire and tow bar removal (less 50kg)
  • Engine cover delete (heat soak)
After all this was done it really transformed everything about the car. drove like new and stopped a bit sharper. Exhaust isnt loud and really opens the 2j up. Especially up high as it now pulls like a kiddy fiddla at a wiggles concert after 80km/hr. Dont know if its the earthing kit/voltage stabilizer or extra air but i dont have to put my foot down as far on the loud pedal to invoke a response. Probably better on petrol too which is always 98 RON
post-8513-0-07679500-1448741988_thumb.pn extra cold air ram
post-8513-0-42574300-1448741667_thumb.pn Rims are SSR Viennas. 10's rear.9's front. (cant remember offset) Tires are Kumhos 225/40 R18 (f) 265/35 R18 ®
Future plans are tint, front lip (ordered from ebay and coming mid month) sound system upgrade, maybe a strut brace. bigger tires front to fill out guards and smaller ones rear to clear guards as scrapping occasionally.
Thanks all. comments and suggestions appreciated.
I think I forgot to mention the 5litres of Mobil 1 5w-50 oil change and engine flush prior. Also new toyota air filter which flows better than aftermarket. As some of them ive noticed have solid sides which impede air flow. cheers
Hello & welcome, a nice GS. you will enjoy it.
  • Like 1
cruise tonight in Perth if anyone keen? Weather permitting
  • Join The Club
    Lexus Owners' Club Australia is an Independent Lexus Owners Club.
    Join our Australian LOC community. It's FREE!
  • Latest Member Posts
    1. 0
    2. 0
    3. 10
      Driving Light
