I am a long  happy owner of a 1997 ES 300, regretfully the only function recently not operating is the Drivers Side Window switch! All other functions from this consul work.
Have checked window motor/regulator all good operates up/down with limited (approx, 3 amp) current drain..
VIN, Photos etc. can follow but first asking my fellow 'L' friends for a next step.
Regards
Chris
  • 2 years later...
Common problem on the BA Ford Falcons. Often the switch needs to be removed and the metal contacts within cleaned with meths and sandpaper.
Meths or rubbing alcohol is ok but sandpaper will take off the thin silver plate.
Use a bit of an old stocking etc.
