Hey Guys:
This Thread will be pinned and it will be a place where members can find what they need about their cars in terms of aftermarket parts etc. PM me for comments. :lol:
Matt
OK, to start off with, I don't have much knowledge with the GS's...
http://nz.lexusownersclub.com/forums/index...ct=ST&f=3&t=84& (Engine Oil)
http://nz.lexusownersclub.com/forums/index...t=ST&f=3&t=135& (Yokohama Tire Review)
http://nz.lexusownersclub.com/forums/index...ct=ST&f=3&t=67& (Brake Pads)
More to come.
Edited by LsportlineIS300
  • 3 years later...
1996 JZS147 Toyota Aristo 3.0V (GS300)
GENERAL
Body type Sedan
Drive FR
Transmission Electronic control type 4 speed automatic (intelligent) ECT-i
Displacement, cc 2997
Frame E-JZS147-BEPVZ
Price of new car, thousands yen (Tokyo area) 4790 (~$39900)
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 4920 x 1795 x 1420
Interior dimensions (LxWxH), mm 2005 x 1535 x 1150
Wheel base, mm 2780
Treads (F/R), mm 1535 / 1510
Ground clearance, mm 150
Curb vehicle weight, kg 1690
Gross vehicle weight, kg
Seating capacity, persons 5
Doors number 4
Min.turning radius, m 5.5
Fuel tank capacity, l 80
Engine model 2JZ-GTE
Max.power (Net), kw(PS)/rpm 280 ps (205.94 kw) / 5600 rpm
Max.torque(Net), N*m(kg*m)/rpm 44.0 kg*m (431.49 N*m) / 3600 rpm
Power density 6.04
Engine type Water cooling serial 6 cylinder DOHC24 valve twin turbo
Engine information 2 way twin turbo
Fuel system EFI (electronic fuel injection)
Turbocharger Twin Turbo
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 8.5
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 12.9
Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Power steering Yes
Tires size, front 225/55r16 94v
Tires size rear 225/55r16 94v
Braking system, front Ventilated disk
Braking system, rear Ventilated disk
Suspension system, front Double wishbone type coil spring
Suspension system, rear Double wishbone type coil spring
EQUIPMENT
EXTERIOR EQUIPMENT
Sunroof / Moonroof
Front fog lamp
Rear fog lamp
Xenon headlight (Discharge lamp)
Projector headlight
Rear wiper
Front spoiler
Rear or roof spoiler
ABS (Antilock brake system)
TCS (Traction control system)
LSD (Limited slip differential)
Privacy glass
UV cutting glass
Aluminium wheel 16inch standard
INTERIOR EQUIPMENT
Air conditioner Full automatic
Wood panel
Cruise control
Centralized door lock
Power window
Steering wheel telescopic
Steering wheel tilt
Leather steering wheel
Power front seat
Power rear seat
Leather seat
Falling down type rear seat
Child seat fixed with seat belt
Rear ELR3 point seat belt
Front seat pretensioner seat belt
Fourth limited front seat belt
Side impact bar
Airbag (Driver)
Airbag (Passenger)
Airbag (Side)
Audio deck AM/FM radio equipped cassette player
CD-player Single equipment
Car navigation system
- present - not present - option
Colors
Color spectrum Color
Black
Dark blue mica
Grayish green mica metallic
Silver metallic
Option
Dark green mica P.I.O.Toning G
White pearl mica toning G
  • Join The Club
  • Latest Member Posts
    1. 0
    2. 0
    3. 10
      Driving Light
