  • 1 month later...
Another option is go for a big brake kit.
You can fit the Supra 4-pot calipers without any modifications, and together with the Supra rotors this will be the cheapest upgrade.
Then you can also fit the TRD bbk. Will significantly improving braking and the brake feeling.
if it's just spongy as the feeling of the brakes and you do not need alot of extra performance out of your brakes all you have to do is go for some brake lines...if you need to source the brake kit or brake lines I m always here to help...
Matt =)
