Polisher
I wouldn't recommend using any rotary applicator - these usually cause swirl marks in the first place.
Car washes typically use them and I've spent a lot of time on my previous car trying to remove the swirls.
I used Zaino Z2 & Z5 and hours to get them removed. The polish needs to go vertical on doors and horizontal on roof, hood & boot.
A Dual Action Polisher is different to rotary, it is almost impossible to cause additional swirl marks using a DA.
Good thing about the DA system is Meguiars have developed a wide range of compounds, polishes and pads specially designed for use on DA.
There's a good write up at
http://www.meguiarsonline.com/forums/showthread.php?49385-KBM-Pad-Priming-and-Supplemental-Wetting-Agents
Seems like these do a good job, however it still doesn't do vertical or horizontal lines which is what you'd want for a sealant application. There'll always be some rotary type action due to the nature of the mechanism.
Frank is correct though, they're unlikely to cause additional swirls.
