No Telephone Function To Connect Phone Via Bluetooth
Hey guys,
I have a 2007 IS250
So recently I had to get my digitizer replaced and it turns out the ribbon cable thing (technical name?) that connects to the screen cracked on the side? We couldn't find any other ones (but if someone could help us get a replacement ribbon please!) so we mended it.
Everything works now except when I went to Info to connect my phone to bluetooth I didn't have the Telephone function in there? I've been searching for a thread but coudln't find anything.
Any help would be appreciated pls.
Thank you!
Doesn't make sense that a digitizer cable will affect the bluetooth function of the navigation. Most likely somewhere during the repair/dismantling process something was dislodged or damaged. Your best bet will be to either take the thing apart again to see if you need a whole replacement unit.
  • 3 weeks later...
I think you missed a plug.
HOLD down INFO button. Turn your lights on 4x
Then go through diagnostics. You should see the error in there somewhere in the BT/Phone menu.
Hey guys,
I have a 2007 IS250
Thank you!
