Latest Member Posts
10
Driving Light
33
Hey Lionel, is this person still available to do touchscreen replacement in Perth, even for a fee? Same issue on my 2007 IS250 with the touchscreen broken. Thanks in advance -
Service Centres
Can you recommend anyone who does Lexus service? 2010 model.
