Is an LS350 the same as an IS350?
If so if you have the DVD map model it can be done from the post further down the page. If its the SD card version you are stuck with updates from Toyota only atm.
Note: DVD map version has 2 little holes each side of the lower clock panel that you insert a rod into to remove panel and show DVD map slot.
(The removal tools should be in the tool kit)
