New IS300 owner
Latest Member Posts
10
Driving Light
Hi Peter, After taking onboard your suggestions and a few good nights sleep to mull over options the new driving lights are installed and working. No holes were drilled into vehicle but I did cut a small slot into back of the larger plastic fuse box cover/lid to source power from jump start terminal. (12v battery is in boot of NX 450h+) The wiring was a little fiddly but not having to take the dash apart was a huge bonus to installing the XBB kit. Was able to ‘reuse’ relay base from wiring harness supplied with Ultra Vision lights. Fitted a 20 amp inline fuse as lights draw 13.2 amps total. Smart button works a treat so can have high beam on without driving lights. So glad that I found this forum when I did, Neil -
33
LEXUS IS250 TOUCH SCREEN DOES NOT WORK - PLEASE HELP!!!
Hey Lionel, is this person still available to do touchscreen replacement in Perth, even for a fee? Same issue on my 2007 IS250 with the touchscreen broken. Thanks in advance
