Latest Member Posts
3
3
RX450H 2010 Check Brake system amber light
I have a Lexus 2013 model 450rx hybrid and had the Check Brake system message while driving today. I got the vehicle after service last thursday, any advise -
3
Driving Light
Hi Darren And Bazzle, The NX300 proved to be very challenging to fit driving lights. Like Bazzle, in the past I have found a high beam light wire and used it to run a relay to link in the driving lights. The challenge proved to be the CANBUS electrical system that runs LED headlights. An excellent mechanic and I tried finding a high beam fuse, but there wasn't one, and to make it worse, there are two sets of fuses under the bonnet that are identical. I ended up buying an XBB kit that uses a dongle in the OBD2 terminal to read the high and low beam lights on. This was then programmed to send a Bluetooth signal to a Relay under the bonnet and this is called a power unit. With this Swedish unit the driving lights synchronised with the vehicle high / low beam and worked perfectly except for one thing, I could not turn the driving light off and just use the NX high beam. To overcome this issue, and to make the driving lights operate legally, I then bought an XBB Smart Button to link in with the dongle and permit turning off the driving light and still maintain the NX high beam. This button also turns the driving light back on when the NBX lights are on high beam. With this system there is no wiring done inside the vehicle and the relay (power unit) is wired in exactly as you would wire in any normal relay for for lights. If you are interested in learning more about the XBB system, do a search for XBB. I cannot insert the link as this dialogue box will not permit me to. There is Swan Hill firm the markets the bits and its name is Ultra Vision Sales. The NX300 high beam lights are now fabulous, not just good as they used to be. Another advantage to the XBB system, is that you can easily take the important bits with you and program them into another vehicle that has CANBUS lights. Golden Eye
