First morning start the engine revs to around 2000 rpm then slowly idles down to normal, should this happen at nearly every start up, i know they dont have chokes now days, and should it be engaging in the warmer weather, any suggestions out there would be helpful  👍
But it will do in 35deg heat and  after sitting for a couple of hours.
if its doing when the temp needle is on low (Cold) its fine
