Does anyone know if i could change my front end over to the newer shaped model i have an aristo 94 model and would like the twin headlight look.
Cheers
  • 3 weeks later...
Not without extensive modifications. If you've got plenty of money, then your best off buying a late model Aristo Nose cut from japan and then swapping over the Bonnet, guards, front bar, radiator assembly, headlights, grill etc...
Lots of money involved in labour and prep work. You may even need to cut up or even lengthen the bonnet etc.. in order to it to fit on the 147 engine bay.
If I were you, go and find a GS300 and take some measurements before you even think about it :)
Ben
  • 3 weeks later...
I would be surprised if they even get close to fitting.
The two cars were designed by 2 different places.
I don't think they share much at all except the name and the engine.
Chris
