Does anyone have a detailed pin out diagram for the 1G-FE [iS 200 Australian] ??
I am trying to set up a SAFC II but without this information i cant do it!
Cheers,
MattD
I have the complete IS200 wiring diagrams (all 600 pages of it).
Let me know what signals you are looking for and I can find them for you.
Alternatively I have a spreadsheet of the connections onto the engine computer that I used to wire my 1JZ unit into the car. It has almost all of the signals on it.
Graham
Thanks Graham,
I just need the pin out from the ECU so i can plug into the APEX-I SAFC II to put it on a dyno and adjust accordingly....
Cheers,
MattD
We worked it out, it is all wired up/in now. Going on the dyno tomorrow.
Thanks anyway, i will post some pics of the mods i have done over the weekend for everyone to have a look at.
MattD
  • 5 years later...
MattD
what were the pinouts? i am trying to fit an safc II to my 03 auto is200.
pins required are:
Connect the red wire to the power supply.
Connect the green wire to the engine rpm signal wire.
Connect the gray wire to the throttle signal wire.
Connect the black wire to the ground wire.
Connect brown wire to the ground wire.
Connect the purple wire to the knocking signal wire ・・・※
※For models with a single knocking wire.
Connect the purple wire directly to the knocking signal wire.
※For models with multiple knocking wires (knocking signal 1,
knocking signal 2, ・・・)
Refer to page 11 without making any connection at this time.
  • 1 year later...
Hi Graham could you PM me your email addy please as i would like to get some more info from you please. im in South africa and the guys here are crazy and i dont think they know how to mod a lexus please bud.
  • 2 years later...
Hey graham im trying to perform is200 to 2jz gte conversion and am in need of the wiring diagram. Is there any possibility that you could send it to me?
  • 6 years later...
Goodday, recently installed a 1gfe beams from an is200 in my 1986 toyota crown. Wired up and most stuff is working. Problem is my overdrive isn't coming in. The electrician told me I need a signal from the abs however my car isn't fitted with abs. Is there any other way to get my overdrive working? All other gears change fine, just overdrive not going in at all. Thanks much.
  • Join The Club
  • Latest Member Posts
    1. 0
    2. 0
    3. 10
      Driving Light
    4. 33
