Spring / Brake Replacement Suggestions?
Hey there
Just bought an IS250 2007 sports with 97,000km on the clock
The brakes are almost done so I need new ones, i'd like some good sporty ones, will spend $100-300
Also want to lower the car from factory height (not too much, but definately lower than stock),
but try to keep the ride softness much as possible
Can you guys recommend a brand of brakes / springs to get
Also, I live in gold coast, so if you can recommend a place to buy/install them feel free
I'll check it out
General concensus seems to be that you can't get the same soft ride with just springs
need coilovers, though haven't been able to find out if they're as soft
i ran coilovers in my previous is250 (BC coilovers)
They were nice and low though provided slightly stiffer ride compared to stock
no aftermarket suspension will provide you with the same nice soft ride of a stock car
but the BC coilovers with 30levels of damper adjustment you can get close to it
Semi pissed off
Went to a workshop got a quote $156 for bendix general front brakes & $156 for rears. Okay no biggy
Guy said I'd also need to machine the fronts at about $35
Then after its done he charges $88 for machining, $80 for labour
I could have gone and bought new performance discs for like $150 $200 what the hell do I want machined ones for at that price
Also could have got the brakes on the net for $104 each but thought I'd help a local out
Some good that did..
Yeah I made the mistake of getting them to do it when they have a mobile machiner who charges them $45 callout fee
So yea basically idiot of me for using a workshop that has mobile people to do machining
Oh well its done now
Can you tell me a bit more about your coilovers?
Whatd they cost you $$
Would you recommend them?
I dont mind a bit stiffer but i'd like to retain maximum softness possible while getting some lowering cause stock is too high
well yeah very recomended for the price
1300 delivered to your door
BC coilovers
they have 2 versions
get the V2's as they have fixed the clunking issue from the V1 in the V2
You can be lucky though if you opt for the v1. But why bother with it when the v2 is only 150 bucks more and the v2 have a bigger shock absorber for better handling control / adjustment. (track to street). (hard action to soft luxury)
Highly recomended. Its not overly stiff. More firm then anything.
  • 10 months later...
