hi guys
when i bought my is200 i only got the sub key i bought a broken key with buttons from uk for $20 fitted new battery, replaced case and shaft and cut for free from work then i programed the new key to car by turning it into a master key through the ecu but when tring to get the remote coded the car would not enter code mode told by auto locksmith that it was because the ignition key warning noise wasnt working (the noise when you turn the key off and leave it in and open the door) also seat belt warning noise and passenger seat belt light inop i checked over all fuses and relays all ok anyone have any ideas
I used to know how to do all of this. Ill have a look and see if i still have the info
  • 4 weeks later...
Hi
I have no idea whether you have checked this or not but here are some pages i thought might be helpful. I bought a pdf is200 repair manual from ebay and its pretty helpful
m_be_0022.pdf
m_be_0023.pdf
As for the passenger seatbelt light not lighting up these may help look at point 25 and 26
m_be_0083.pdf
m_be_0075.pdf
