Hey I just got my Vossen CV2's fitted and they seem to be rubbing extensively, It'd lowered with BC coilovers. Running 20*9 225/35 Front and 20*10.5 245/35 on the rear. Besides rolling the guards and using a heat gun on the inner liners what else can I do to fix this besides raising the car.
I went to get the front guards rolled and was told couldn't do it as the liner would come off. Anyway around this?
Cheers.
Ha I was going to say they are pretty stretched as it is.
Running +38 at the front +45 Rear.
Yeah going to stiffen, the front a bit and go from there.
  • 4 weeks later...
Yeah cheers, the rears are fine.
Mainly when I hit bumps, turning is fine now
Will stiffen the fronts when I get back and see if that helps if not might have to cut the liner and roll the guards and just run with it. Been away in Hawaii for 6 weeks
well for a start your runing 20's
should be running 30 profiles
35 is what i have on with my 19's
i actually have 30's on the rear
i had 9.5 with +35 offset and 10.5 with +42
ran 225/30/20 and 255/30/20
im pretty sure it's your tyre profile
  • 3 weeks later...
So changing the profile of my tyre will solve it, I rolled the guards and stiffened the fronts, now barely rubs but when I drive. Thanks for the help
