Just for the google record. The 350z 18 inch wheels fit well and look good.
Will order hub centering rings for $25 for the sake of technical perfection, and getting the blank central caps in 54/50mm size appears to be a chor, but otherwise a very good option. A good set of Nissan take offs could be had for a killer deal.
I got mine with staggered tyre option. 245/40/18 rear and 225/45/18 front. Yoko advan sport with 5k on them:-). Seems to be working very good.
Should be 245/45 on the rear. Will fill the fenders more. Did you get hub rings to hepl fit it on?
245/45 for the rear sounds like the right idea. Hm, maybe next set of tyres in that size. What about front ones? Would 245/45 work well up front?
I ordered the aluminum rings from UK. Yet to arrive.
Driving without rings for now. No issues, really.
225/45 and 245/45 were stock tyres for the wheels. I think 40 looks too thin. 45 help fill the guards.
I heard aluminium rings sticks to the hub, ebay sells 66.1 polycarbonate ones for cheap.
I heard that too. However, there must be a lot of heat applied to make the aluminium and steel bond together to the point of diffusion. If such thing is possible at all .
How much did you paid for your set?
So you got them for free in other words?
Heh, I thought you were referring to centering rings.
The set of wheels sure didn't cost 28 bucks. Not that lucky. It cost me less than $500. I was quite happy with the deal.
