Glorified Dus Briver Posted March 29, 2017 Share Posted March 29, 2017 G'day all, My first post here as I'm in the market to buy an IS250 after much research. Recently went to inspect a 2011 IS250 prestige which I thoroughly liked. This one has the sunroof and the leather trim (option pack). During the visual inspection, I found the rear view camera mounted right above the number plate, however, there is no satnav in the car. There's no screen/display where the rear view camera is hooked up to. I'm concerned about why this 2011 model would have a rear view camera but without anything to display it on. Seller claims to never have had the satnav, however, I'm still not convinced. Could somebody please provide some input. Thanks and much appreciated! Quote Link to comment Share on other sites More sharing options...
ilv1004s Posted March 30, 2017 Share Posted March 30, 2017 (edited) is this car in australia? my understanding is all is250's from 2011 onwards came with satnavs only option available with the presteige was the cooled seats and sunroof which goes together from factory option highly possible the car had its unit replaced for some reason if it has factory rear camera it should have a nav so sum it up 2 possible reasons 1. Car did not come with satnav and owner somehow added the reverse camera 2.Nav screen was replaced by some base model non nav screen first possibility is highly unlikely AFAIK all 2011 came with satnavs Edited March 30, 2017 by ilv1004s Quote Link to comment Share on other sites More sharing options...
Glorified Dus Briver Posted March 30, 2017 Author Share Posted March 30, 2017 1 hour ago, ilv1004s said: is this car in australia? my understanding is all is250's from 2011 onwards came with satnavs only option available with the presteige was the cooled seats and sunroof which goes together from factory option highly possible the car had its unit replaced for some reason if it has factory rear camera it should have a nav so sum it up 2 possible reasons 1. Car did not come with satnav and owner somehow added the reverse camera 2.Nav screen was replaced by some base model non nav screen first possibility is highly unlikely AFAIK all 2011 came with satnavs Thanks for your input. Yes, this car is in OZ. I performed a VIN number check and seems like it was a fleet vehicle during the first purchase. Between then and now, they might have removed it (can't confirm) but the only logical means of making sense is that it either came from factory or added aftermarket. I'm not too fussed about the satnav/RV display but was just interested to know if it was default in the 2011 models. Is this something I should really be worried about? Quote Link to comment Share on other sites More sharing options...
ilv1004s Posted March 30, 2017 Share Posted March 30, 2017 could have been a listing error maybe do you have pics of the actual car? might have been a 2010 advertised as a 2011 Quote Link to comment Share on other sites More sharing options...
ilv1004s Posted March 30, 2017 Share Posted March 30, 2017 just a quick search 2010's didnt come with nav standard https://www.carsales.com.au/private/details/Lexus-IS250-2010/SSE-AD-4641875/?gts=SSE-AD-4641875>ssaleid=SSE-AD-4641875&rankingType=Spotlight 2011s pretty sure they all came standard with nav easy way to tell between a 2011 and 2010 is the front bumper bar and also interior trims if they are black on the centre console and window switches presteige 2010s were grey Quote Link to comment Share on other sites More sharing options...
Glorified Dus Briver Posted March 30, 2017 Author Share Posted March 30, 2017 24 minutes ago, ilv1004s said: could have been a listing error maybe do you have pics of the actual car? might have been a 2010 advertised as a 2011 Sent you a private message. Quote Link to comment Share on other sites More sharing options...
Glorified Dus Briver Posted April 4, 2017 Author Share Posted April 4, 2017 The mechanical inspection found that the rear-view camera was an after market mount clearly evident by the poor silicon job around the mounting. Thanks ilv1004s for all the help and advice! Quote Link to comment Share on other sites More sharing options...
