How do you guys do the perfect launch in your F's? Just put the foot all the way down from idle? Build revs in N then shift to D?
There's a thread on this at Clublexus forum, and the consensus between the super-fast guys is that on the dragstrip, you don't brake-stall it but just tromp it from idle when it goes green.
That's on a rubber-coated dragstrip of course, but I can imagine it would apply on a less-grippy street surface too.
And it's damaging to the trans to do a "neutral drop".  If you want to lay rubber, put it in D...left foot hard on the brake and build revs to about 1500rpm with the right foot.  Release brake and marvel at the smoke show (assuming that one does not crash in the process) 🙂 This process is called brake-stalling, it's like dumping the clutch in a manual.
This guys explains it well https://youtu.be/Mig14z78MbY
I remember way back in 1976 at tech a bloke leaving revved his car up and dropped it into drive bang, tail shaft on the ground in pieces, no its not a good idea.
The clutches which manage the shift from N to D aren’t designed to transmit the torque (or cope with the shock) of a neutral drop.
It’s not even something that I’d do to a rental car 🙂
Building revs to 1500rpm with the wheels brake locked doesnt damage the tranny?
I know what you're thinking, which is that surely brake-stalling the trans has an element of friction or slippage, like slipping the clutch in a manual, but it's not the same as a neutral drop, and to explain why, you have to see what an auto transmission looks like inside.
Here's a trans I had rebuild a while ago; it was an electronic 4spd auto, the sort that was quite common until the early 2000s.  The 8, 9 and 10 spd autos we have today are ironically more compact, but the principles are the same, and it's far easier to visualise how it all works with an older style trans like this one.
Toys035.jpg[i
The way an auto works is that each gear is like a spinning drum (which you can see several in the pic above).  And here's one below:
In Neutral, all 4 drums are spinning, and no drive is being sent to the wheels.  In the pic above, you can just about see the clutch band wrap around the drum.
When you select Drive, what happens is that hydraulic pressure wraps the band tight around the drum, forcing it to stop spinning. This engages gears inside the drum, and 1st gear is now selected.  When the trans shifts to second, the hydraulics release the 1st gear band, allowing the 1st gear drum to spin again, and engages the 2nd gear band which stops the 2nd gear drum from spinning, and so on and so forth.
But unlike the clutch in a manual, the clutch band in an auto is a frail looking thing, with only a very thin friction lining.  It's immersed in a bath of transmission oil, and it engages with hydraulic pressure, rather than the massive clamping force of a manual clutch spring. Here's some clutch bands below, and as you can see they're not terribly robust and are really just strong enough to disengage one gear and select the next.  They aren't actually designed to transmit the torque of the engine at all.
When you do a neutral drop, you have the 1st gear drum spinning at huuuge rpm (instead of idle rpm like normal when you shift from P to D) and the little clutch band has to arrest it and engage 1st gear.  Basically it isn't designed for any of that,  and isn't strong enough to absorb the shock from a clutch dump (or neutral drop).  And that's why a neutral drop is a very damaging thing to do to an auto trans.
So now you're thinking...so what happens when you brake-stall it to 1500rpm? Well now you know that when you're doing a brake-stall launch, the selector is in D, the 1st gear drum is locked in by the clutch band and the trans is good to go.
The "slippage" is not inside the trans at all, but in the torque convertor, which looks like this:
Best way to understand what it does, is to imagine that the donut-shaped casing is bolted to the flywheel, and spins at engine rpm.  Now imagine a shaft from the trans going into the donut, attached to say, a paddlewheel from an old style steamship.  Now imagine that the inside surface of the donut is full of vanes, and the whole shebang is filled with custard.
As you rev the engine, the donut casing will spin, and the vanes will move the custard, which will eventually move the paddlewheel...and the transmission will now spin, too. Inside the torque convertor the metal parts don't contact each other at all, and it's the custard that transmits the force from outer to inner.
Now, the torque convertor is always working with a certain amount of slippage, for example when you're stationary in D...the donut is spinning at idle rpm but the paddlewheel is held stationary by your foot on the brake.  This happens all day, everyday.  The transmission fluid (it's not actually custard in there 🙂is designed to cope with that.  Brake-stalling increases the amount of slippage, but it isn't actually a mechanical slippage or impact; it's basically just the custard/fluid that is being whipped into more of a frenzy than usual.
Now, if you brake-stalled it to 1500rpm and held it there for a really long time, then you can imagine that the fluid will start to overheat, and that's not good for it.  But a brief brake-stall for a heartbeat as part of a launch is actually far less of a mechanical shock than dropping the clutch in a manual. A neutral drop is actually very similar to a clutch dump in a manual, except that the components taking up all the shock aren't really designed for it.
  • Like 2
Watch this guy from America - he has oodles of 1/8th mile drag race videos in his IS-F. https://www.youtube.com/channel/UCkbxMFEyJ_3_6B5hZDZ_hog/videos
It seems that most of the times he just mashes the throttle and other times he stalls it up a little bit - but he has a very good reaction time which is why he wins so many races. He also leaves the traction control on to limit time wasting wheelspin.
That bloke knows what he's doing, he seems to beat absolutely everything 🙂
Yes he wins many races which i would think he should lose - but his concentration and reaction time does wonders for him i think. His only modification to the car is an xforce exhaust too - totally stock otherwise.
I reckon it makes a difference that he's racing 1/8th mile.
If it was a full 1/4 mile, even with the worst launch, some of the fast stuff he manages to beat like Hellcats would claw back the advantage
Is this old mate?
I guess maybe he doesn't post vids when he loses (which has to happen some of the time)
Yes thats him (white ISF on the same track so chances are its him). Those Stingers are fast so im not entirely surprised it won.
Cheers, guys! Thanks for the tips and teaching about the transmission 🙂
As soon as I get mine running again I’ll be seeing a transmission guy I know to see what stally options I can look at.
  • Join The Club
    Lexus Owners' Club Australia is an Independent Lexus Owners Club.
    Join our Australian LOC community. It's FREE!
  • Latest Member Posts
    1. 0
    2. 0
    3. 10
      Driving Light
    4. 33
      LEXUS IS250 TOUCH SCREEN DOES NOT WORK - PLEASE HELP!!!
