picked these babies up yesterday
fresh from japan YO!!
this is just a basic guide i didnt have time to take any fotos and im not god at wiring these kinda stuff
so step 1
take off all the covers and such in the engine bay
then undo your wheels
undo the nut that connects the shocks and the lower control arm
ad jack the control arm to get the sway bar bushings out
all the bits i'v circled in you must undo.. and pop the hub out
undo these nuts on the top of the strut tower
then take the shock out an replace the OEM shocks with the new springs
and reverse the order te assemble
Step 2
For the rears
take out the rear interior as such
loosen and take out the circled bits
loosen and take out the 3 bolts that hold the shcks/hub and sway bar mounts
but u only have to loosen the nut thats on the lower subframe (circled)
once u have done so this will happen
to get the shocks out there are 2 bolts that hold the shocks to the chassis of the car
they are under a dust cover and u need to undo the 2 small nuts to access the shocks
once u have taken out the cover you will see this
undo the circled bolts.
take out the shocks and fit th new sprins in and reverse the order for assembly
and this is how my car looks right now
from this height
to....
This!!
Is it an even finger gap front and back?? Do you think that you will have to roll the guards or you have definately put it through its paces with no scrub!?!?!?! Like I said man, if you can post a close up pic of the wheel arch's, atleast then we will all know what type of drop to expect from the Teins ST's. Then when Cevu gets the F-sports on, we can get a reference for them as well. QQQ, can you post a close up pick of the Eibach's drop!!
Thanks y'all!!!
Thanks y'all!!!
haha...... and there it is again...... my fsport springs get a mention! :-)
ilvs004, damn nice job! thanks for the writeup. will definitely come in handy at some stage!
looks real good, but close ups would be great when u get a chance!
just in time to show it off for the 25th :-)
Thanks y'all!!!
C'mon man, im cheer'n for ya!!! U be the only one here ride'n with the F-Sport springs!!! ;) If cash is an issue, why don't the 3 of us hook up and do the springs together!! Ilv is an expert now!!! We could probably do it the night of the formal!!! You down???
Thanks y'all!!!
appreciate the offer projectis but savin for fsport shocks as well so i'm going to get them down in one go! cmon! i did the headers...... now i get a break!
than i'll be back with the fsport springs/shocks combo! :-)
