hi all.
i have just put a deposit down for an Is250 2006.
I have test driven the car all good no vibrations or anything like that...
the only thing is the is a clicking noise coming from the engine...
i want to make sure it is not something to serious.
I have read there was a recall on the Cam gear on the is250s but i am unsure if this is cam gear or not...
see blow
http://www.youtube.com/watch?v=QR1N-gONuLw
i have booked it on for an inspection with a lexux dealer for the 94 point safety check etc...
The other thing is that when driving the car, if the car excedes 3k rpm the tachometer goes orange until it changes gear..
Sounds like the injectors when the engine is cold.
You can adjust the tacho to light up at any RPM you like... there is a button to the right of the steering wheel to adjust it.
but it makes the noise when the engine is warn and at running temp.
i have been reading about the Cam gears and Broken valve springs...
hey buddy thats the injectors
quite normal on a is250
also with the tacho lighting up orange
that can be changed by the dial set up on the right side of your steering wheel on the dash
press the little button and you can play around with the tach and speed warning settings
All direct injected engines have little louder that usual injectors so the sound that comes out is similar to the sticky lifters.
Yep, direct injection mate.
Ever wondered why a diesel sounds like a diesel? And an IS sounds like a diesel?
  • Join The Club
    Lexus Owners' Club Australia is an Independent Lexus Owners Club.
    Join our Australian LOC community. It's FREE!
  • Latest Member Posts
    1. 0
    2. 0
    3. 10
      Driving Light
