Well done to Jason for breaking the struggle to get outta the 11s and into a 10. Lots of behind the scenes work and inovations done by the owner to get where he is today. A good bar has been set, we’ll be coming for it soon 👍
Yeah saw his post on FB.  Impressive results.  I could only imagine how much $$$ he'll need to spend to get into the 9's lol.
Bloody fast but no doubt big $$ spent and hours fine tuning and adjusting etc. Any idea if the gearbox and driveline is still stock? And i assume the engine has been rebuilt with forged pistons and rods at a minimum. Does anyone do cams for these engines?
Gearbox has a larger oil cooler, driveline is still stock ratio he said, yeah it had a rebuild after it got a knock not long after the initial Sc install, if you’ve seen our cams it would take a hell of a lot of development to produce a aftermarket set especially with the lift on both intake and exhaust.
At most I imagine you could do a spring upgrade but would only warrant that if you had float or wanting to rev it harder but at this stage it isn’t warranted.
It won’t get there, the Sc unit is way past maxing out and it would be a pretty dramatic conversion to upgrade the intake injector system to convert over to full e85 but would be pointless only running single digits of boost.
If I remember correctly our cams are a titanium alloy and hollow, so no one has ever touched a set to R&D for performance upgrades.
