For anybody interested, the last week or so I've been in the process of fitting brembos to the front of my 3IS, With a little mucking around with different rotors etc.
Here is what will hopefully be the end result.
Just need to bolt on brake lines, possibly take a little meat off my spacers and give them a bleed.
I've used a slightly thicker rotor than factory.
3 hours ago, bazzle said:
What is the rotor off?
I have rotors that look the same but are standard is350 (2011) size.
I've used a larger width rotor in comparison to the ISF not the IS350, the rotors is a 355 mm rotor, I've had it up and running now, seems great finished about 30 minutes ago.
Wish I could have offset the caliper another half a mm in but it could possibly be something else I will sort down the track, realistically it shouldn't be a problem in terms of pad wear etc.
Master seems OK,
The capacity in theory isn't a great deal larger considering the factory calipers.
Even stopping power wouldn't be overly better, larger surface area for heat dissipation on the other hand...
I only fit them due to getting them for a really good price.
what car are the brembos off?
or is it a aftermarket kit
physically the MBC wouldnt be a problem but it will be softer feel than a factory brembo equipped car IE RCF/GSF/ISF
which in means more pedal travel
Edited by ilv1004s
  • 4 weeks later...
Hey mate,
They are ISF brembos.
I agree, pedal feel is factory, a little firmer would be ideal but beggars cannot be choosers.
