New Tyres Sumitomo Htrz-Iii
Latest Member Posts
67
GPS v25 (probably v22) 2019 for Au/Nz DVD based vehicles not SD card
To anyone trying to burn the V25 ISO file shared by bazzle I had the same issue as Eli, where the DVD I burnt, loaded up fine, but it wouldn't let you put in a new destination. So I re-burnt the image using the following settings. DVD: Verbatim 8x DVD+R DL (Same disk during the first attempt. Issue was not the disk) - Used PowerISO to burn the disk (Instead of the Windows Default option to burn, that I used in the first attempt) - PowerISO gives the option to drop the burning speed to 3x. - Unchecked, "finalize disk" (Not sure if this makes a difference). Hope this helps. Again, big thank you to Bazzle...! I called Lexus a few days ago and they wanted $425 for a disk that they said was the last version that was officially released, which was version 24 and has maps current to 2017. If anyone gets their hands on this, please care to share the ISO file here. PS: The V25 ISO seems to be bundled in 2018 as per the file time stamps, so I assume this one is newer than the last official release. If anyone knows more information on the source of the V25 ISO, please do share. -
4
Overtrail Owner (to be)
I ordered the sand colour, I think it’s called Desert Moon?
