Automatic Transmission - Fluid Change
Latest Member Posts
10
Driving Light
Hi Peter, After taking onboard your suggestions and a few good nights sleep to mull over options the new driving lights are installed and working. No holes were drilled into vehicle but I did cut a small slot into back of the larger plastic fuse box cover/lid to source power from jump start terminal. (12v battery is in boot of NX 450h+) The wiring was a little fiddly but not having to take the dash apart was a huge bonus to installing the XBB kit. Was able to ‘reuse’ relay base from wiring harness supplied with Ultra Vision lights. Fitted a 20 amp inline fuse as lights draw 13.2 amps total. Smart button works a treat so can have high beam on without driving lights. So glad that I found this forum when I did, Neil
