Hi all, looking for affordable rear tyres. No track, just road cruising and occasional mildly spirited driving if I find some curves.
Have done some research, but user feedback is best. Happy for any suggestions, but cost is an issue.
Some I am considering include (price high to low)
kumho ps91 or 71
hankook h452
kenda kr400
davanti dx460.
Also, should I get a wheel alignment at the same time? Front tyres are fine.
Cheers
If its driving true and tyres wearing nice and even,  on a Lexus I would not touch alignment.
If front have too much inner or outer wear then yes and set front to '0' toe. About all that can be adjusted.
I prefer Michelin's , esp Pilot Sport 4,s
Get a price on those as well, highly recommended on a few forums.
Yep, PS4 are excellent... last two sets of tyres on mine have been PS3 and now PS4
From your list, I wouldn't buy anything less than the Hankooks. I have an odd distrust for those cheap/random brands.
Edited by Atlantis
Actually pricing a set of 235/40/18 and 265/40/18 for mine tomorrow.
Have 225/40/18 and 255/40/18 currently in PS4.
Going up one size to make speedo a bit more accurate (+1.5%) and to help protect rims, esp front.
No an issue in this case. My speedo is 4% high . New tires are 1.5% less when new so now closer to 2.5%.
https://tiresize.com/comparison/
At 100kph on speedo with new oem sizes gps was showing 96kph. Now it shows approx 98kph. I'm happy with that.
New tires cost $1100 the set, from Bob Jane Ringwood, f&b inc old tyre disposal.
Michelin PS4's...
235/40/18 fronts were $160 each.
265/40/18 rears were $390 each
They even look proper on the rims, no bulging, very happy.
Mine runs 4.5% too fast as measured by several GPS units.
When I used to run 20" wheels on the car (285/30/20 on the rear) the speedo would read exactly correct.
I had them on an Audi S3 when I purchased it a couple of years ago. Seemed ok but I did notice a driving difference when I replaced with PS4's.. (my favoutite )
Most likely fine for your purpose.
edit: What are the current front tyres? These  are also important on these cars
Thought about it, but a bit expensive. Ended up getting the kumho ps71s for $380 the pair fitted and balanced.
